Rotary Cutter Rhino 15 ft cutter hydraulic problem
   / Rhino 15 ft cutter hydraulic problem #1
jdmikeska
Hooked up the batwing to begin first shredding of pasture. One of the wings will not go all of the way down. Any suggestions as to cause?
   / Rhino 15 ft cutter hydraulic problem #2
Make sure it's not binding somewhere. You're looking for a hydraulic problem when it may be something else altogether.
   / Rhino 15 ft cutter hydraulic problem #3
Check for a bent PTO shaft. Raise wing all the way up & secure it. Unhook shaft, then let let wing down. If it goes all the way down, then the shat was holding it up. My dad had loaned out his mower & it came back & would not lower.
   / Rhino 15 ft cutter hydraulic problem #4
I used to have an older batwing that would do that. I had to get off the tractor and give it a push or sometimes I could take off and make a sharp turn with the upright wing to the outside and knock it down that way.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
