RH/LH coupling nut
/ RH/LH coupling nut #1
k54frog
Bronze Member
Northern California
Mahindra 2015hst w/hydraulic top&tilt
Hi,
Lost a coupling nut off my 3-pt sway link. :(
specs: M12x1.75 RH/LH thread 80mm long
(Alternative would be 1/2" 14tpi 3.5" long)
Anyone know where to find one for a reasonable price? (around $5-$7) :confused:
/ RH/LH coupling nut #2
See if there is a Fastenal biz around there.. if not, get a grade 8 1/2" bolt and use a lock nut with nylon insert.
/ RH/LH coupling nut #3
Not sure where your going to get a 1/2"x 14 since that is one tpi over standard. Plenty of 1/2"x 13 around if it is just a typo.
David from jax
sandman2234 - Unfortunately it's not a typo. The 1.75 metric pitch is an almost perfect match for 14 tpi.
Of course, just because I can do the math & calculate out the SAE equivalent size doesn't mean it exists. :rolleyes:
/ RH/LH coupling nut #5
Can't you just stop by your Mahindra dealer and pick one of these up? I don't imagine it'll be $7 but it's something they should have in stock.
/ RH/LH coupling nut #6
If you or a buddy welds, you could make one like the adjusters on my old Kubota B6100. Two nuts of the appropriate size and thread held together by two metal straps of the right length. Would be easier to do if they were square nuts.
Vernon
/ RH/LH coupling nut #7
I'm pretty sure the right nut or bolt could be purchased from a good fastener supplier. When I worked at a shop, we had a massive inventory of both SAE and Metric bolts and nuts that we purchased at an auction on pallets. Somebody else purchased the cabinets without the inventory. I don't know why anyone would separate those at an auction, but I guess they had two lots to sell instead of one. I got the job of separating them and putting them in our bin storage, a job I did not enjoy. Luckily most of them were still in bags.
David from jax
Thanks all,
Yes, the local dealer has them in stock but the $25 each price seems a bit steep. I know it's out in the back yard (~1/2 acre) somewhere because it was there when I started working that day. I used a friends metal detector to scan the area but came up empty. Maybe it rolled under a bush. :(
I suppose I've spent more than $25 of my time & effort trying to find another source. *sigh*
/ RH/LH coupling nut #9
Sounds to me it is a 12mm x 1.75mm Metric Thread.
That is a common Metric and you should be able to get that.
The 1/2" is a little big and the 14 is 1/2 thread off.
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2014 Ford Focus Hatchback (A61569)
2014 Ford Focus...
2025 SDLANCH 20x30 All-Steel Carport with Sidewalls (A60352)
2025 SDLANCH 20x30...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A60352)
2025 Wolverine...
Better Built 36 Gallon Fuel Cell (A61166)
Better Built 36...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61567)
2025 BS43 44in...
