Rewiring lights, MF 150
   / Rewiring lights, MF 150 #1
crowbar032
Moores Hill, Indiana
MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
For those of you that have re-wired older tractors, did you go back to the dealer for the factory wire harness? Or did you just run new wires in wire loom? What wire loom, plastic or mesh? Pros, cons? I'm trying to get the lights to work on my Massey Ferguson 150. The wiring inside the fenders has rattled around over the years and worn the insulation off the wire and now only one light works. No electrical issues other than the lights. I'm very tempted to cut the wires below the switch and run bulk wire making up my own connections and covering the whole thing with mesh loom.
   / Rewiring lights, MF 150 #2
I just googled Massey Ferguson 150 wiring harness and it looks like Steiner and Yesterdays tractor has them available. I have a 135 with flattop fenders and used three wire coated trailer wire for my lights. used one wire for the floods and rear, one for the spots and used the white for a ground so I don' have to get ground through mounting surfaces and bolts. Tied on to the existing wire harness on top the differential with wire nuts. Another project left unfinished:laughing:
namyessam
   / Rewiring lights, MF 150 #3
G'day I would just run your own wiring with appropriate fuses and switching
Jon
   / Rewiring lights, MF 150 #4
I used the plastic split loom on my re-wire job, put some black electrical tape on every foot or so to make sure it stayed closed. 4 years later and she's still good, tractor stays outside always.
   / Rewiring lights, MF 150 #5
Having rewired everything from caterpillars to old muscle cars to belly dump trailers, I've found that both spiral and split loom provide good results. However, when replacement harnesses are available, they are often my preferred method of repair. just my two cents worth. Good luck.
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2013 Ford Explorer XLT SUV (A50324)
2013 Ford Explorer...
2016 Ford Fusion S Sedan (A50324)
2016 Ford Fusion S...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
2012 CHREVOLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHREVOLET...
2018 Toro Groundsmaster 7210 72in Zero Turn Commercial Mower (A50322)
2018 Toro...
