Anonymous Poster
- Joined
- Sep 27, 2005
- Messages
- 0
Needing a bit of help on what to do with this new wiring harness that Rainbow acquired for me at a decent price..............
As stated previously, my old wiring harness looks as if it had been rebuilt previously......When I acquired the tractor the wiring harness was pretty well fried from the alternator and starter motor back to the key switch.......Why I think it had been rebuilt is because it was insulated with electrical tape instead of tubing.........so the question might be....what caused the original melt down.......
What I need help with right now is: I have gotten from some very kind members copies of schematics.......they are basically the same BUT a major difference is.........the key switch arrangement to the glow plug is different on the scematics.......one shows a 3 wire arrangement pigtailed together with one end going to terminal 17, another to terminal 61, and the other going to one side of the glowpug indicator......all of these are red and black wiring........................then a black and white wire from the glow plug indicator to the glowplugs themselves..........this is my existing setup...........
The problem is, is that I was sent another configuration showing a wire coming off of terminal 61, through the glowplug indicator, back to terminal 17 and then to the glowplugs...............
If my system has been rebuilt previously, what caused that meltdown, and now what caused this one........I want to get it right.........
Perhaps the glow plug indicator doesnt make a difference.........the wires that were totally fried were the black on terminal 30 and the white on terminal AC.....these run to the starter motor and alternator.........the black and white to the glow plug was in the same bundle so I dont know if perhaps this is where the whole short started because it was wired incorrectly at the key switch.........hope this makes sense........basically what I am doing is getting a new dash and main harness and hooking it up rather than repairing the fused bundles and connector blocks.......the connector block that connects the main harness to the dash harness with the black, white, and black and white glow plug wire are completely melted...........anyway.....any help I can get on which way to install the glow plug indicator wiring would be totally helpful.......thanks again....Dennis
