I can see the advantage but I wouldn't personally install one. The factory fan on newer larger hp tractors is equipped with a fan clutch that regulates the fan speed to control the flow of air through the radiator. A reversing fan eliminates that feature. So instead you have a fan that is constantly pulling maximum air through the radiator. The end result is that you have this constant annoying howling noise from the fan that penetrates the cab. Just buy a leaf blower or a portable air compressor. They are a lot cheaper and do an adequate job. That's my opinion after driving a tractor equipped with one.
