Reversed wheels on pt1430 is a no go.
   / Reversed wheels on pt1430 is a no go. #1
RegL
Platinum Member
Northwestern CT
PT 1430
Well, I finally tried reversing the wheels to do some hillside field mowing. The tractor felt very stable and I liked that open wheeled race car look. ( I'll load a couple pics later.) Trouble is, the wheel track is wider than the 60" brush hog and it left stringers everywhere. I had to mow the field a second time with the Xmark to make it look decent.
If one could find wheels that are centered rather than having so much offset, I think things would be perfect. I did a quick Google but didn't find a dealer for these kind of wheels. Do any of you guys know a place to look? Thanks.
   / Reversed wheels on pt1430 is a no go. #2
That offset is there for a reason. On my 1445, I can not reverse the wheels due to maximum offset. I did have a wheel company make me two wheels with solid centers with bolt holes. They can make them to your specs. I had them set the centers so as to give me a 1/2 in clearance to the frame.
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
Root Rake Attachment (A56857)
Root Rake...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
