Reversed bucket
   / Reversed bucket #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Is this bucket a special use bucket, or can any bucket be used like this. Looks like it would be useful for ditch clean out.
   / Reversed bucket #2
Can't be sure from the pic but it just looks to be curled all the way down to me.
   / Reversed bucket #3
I think the bucket is casting a shadow, and giving it a long tapered look. It's just rolled completely forward.
   / Reversed bucket #4
that bucket is hidding from doing any work. It feels it allready dug enough and is on strike.
   / Reversed bucket
My bucket will only rotate from level, to about 30 degrees up, and to 45 degrees down. Otherwise 75 degree range.
   / Reversed bucket #6
I also think most of what you see is shadow, and is just fully dumped.
Couple of observations though, I don't think mine dumps that far either.
Also those do look like extra long curl cylinders.
And by the look of the bucket pin configuration, it almost does look like you could swap it around.
I really can't think of any good application for a bucket like that myself.
I tried to adjust the pic but it didn't help much, you have to kinda imagine where the bucket outline would be.
jb
   / Reversed bucket #7
What can you tell us about your pic? Something you took a picture of? Your bucket? Not your pic?
Seems there is a story behind this, and maybe you know what it is. :)
   / Reversed bucket #8
it looks like its just curled all the way over with a funny shadow
   / Reversed bucket #9
I think most of it the shadow of the bucket on the ground but I did not think you can curl the bucket almost 270 degrees, is the bucket multi-jointed?
As far as cleaning up ditches the pic below shows a better method perhaps. It was posted by one of the members (Jinman may be ??)some time in the back. I suppose you can get the tractor 90 degrees to a ditch send the box blade in, angle how you need, dig, and pull the dirt right up to the edge or beyond.
JC,
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2013 Ford E-350 Cargo Van (A48081)
2013 Ford E-350...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
Fuel Tank (A50860)
Fuel Tank (A50860)
2013 Fiat 500 Hatchback (A48082)
2013 Fiat 500...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
