Reverse Osmosis Recommendations????
   / Reverse Osmosis Recommendations???? #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
We took advantage of a state pilot to have our well tested for Uranium - our results showed that we are over the EPA recommended levels and we are BIG water drinkers. Recommended solution is a Reverse Osmosis System (under sink mount) for drinking and water to cook with.
I see lots of units out there. I want a high quality long lasting version easy to maintain. I would also like to mount this near the ceiling of my basement and feed the lines into the cabinet under the sink. What do you recommend and why?
   / Reverse Osmosis Recommendations???? #2
We have an EcoWater system under the kitchen sink, with a spout for it. Remember to run a line to any icemaker you have. We rent it and they do the maintance. Filters are costly and need to be changed at least once a year. You will be pleasantly surprised how much better your tea and coffee will taste, and you will have clear ice-cubes. Remember that there will be a 3 gal storage tank, and it will need to be plumed to a drain line.
   / Reverse Osmosis Recommendations???? #4
I've had a GE RO system that I bought from Home Depot, for 9 years. All I've done is change the filters, still on original membrane. As I recall it was only about $120 when I bought it.
   / Reverse Osmosis Recommendations???? #6
Just a little caution here... RO is great but don't use a RO/DI (de ionized) that will harm your innards!
   / Reverse Osmosis Recommendations???? #7
Scotty - what's this state pilot program you speak of? Uranium in your well water? You have my interest given we're around the corner from you. Perhaps we should have our well tested too. We actually have an RO that was put in our house when we first moved in. Our first well was full of everything and anything and ultimately proved to be untreatable, so we had a second well dug. That water has been good, so I let the RO go dormant after a few years. Been thinking of replacing it but just haven't pulled the trigger. Anyway, how did you get your well tested under this pilot program?
Chdinct...give me a call and we can discuss
   / Reverse Osmosis Recommendations???? #9
I'd test for all contaminants (herbicides, pesticides, heavy metals, radon, etc) to be sure you pick the right technology.
After you install a system, have the output tested every year or two to make sure it's working properly.
   / Reverse Osmosis Recommendations???? #10
I've purchased and installed three under sink systems from waterfiltersonline. Whether you buy from them or not, their website is quite informative and eliminates any mystery. It's easy to install a unit and I have no plumbing skills. Buy the tester tool http://www.waterfiltersonline.com/water-tests.asp, track the amount of dissolved solids aggressively and change filters based on that.
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
