Mowing Reverse Mowing switch
   / Reverse Mowing switch #1
kcook
Platinum Member
MI
Cub Lawn Tractor
Does it stay on after being pushed or does it come off as soon as you go forward? Sorry the SC2400 is the model Im looking at!
KC
   / Reverse Mowing switch #2
I don't know what model you are referring to but on my 6284 the reverse PTO switch disengages as soon as you go forward again.
JN
   / Reverse Mowing switch #3
On a Husky it is one of the positions on the ignition switch. Once selected the mower will work in reverse.
   / Reverse Mowing switch #4
KC
KC - Cub cadet's (MTD) jargon name for the feature is RevTech - look for that word around the ignition switch or in the machine's brochure...
SC2400 has a switch on the right side, I just wondered after you depress it once will it stay on or do you need to depress it each time you go backwards?
KC
   / Reverse Mowing switch #6
stays on.
   / Reverse Mowing switch #8
I stand corrected on my 6284 reverse PTO switch. According to my operators manual:
PTO Reverse Override Switch
The PTO reverse override switch is located on the
left fender. Depress the front of the switch to
engage the override which allows the PTO to oper-
ate while the tractor is traveling in the reverse
direction. The indicator light in the override switch
will illuminate when the switch is depressed to the
"ENGAGED" position. Once activated, this func-
tion remains activated until the ignition switch
is turned to the OFF position.
JN
   / Reverse Mowing switch #9
It's been said... but, I thought I'd chime in.
As a Sc2400 owner, I can assure you that you press it once and it stays on until you turn the tractor off. So, for me, that means every time I mow, I just remember to hit the button right off the bat and I'm good until I'm done.
Thanks for the info!!!
KC
1972 Ford F600 Grain Truck (A51039)
1972 Ford F600...
2014 IC Corporation PC505 Commercial Passenger Bus (A48081)
2014 IC...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
