reverse issues on my toro 724-z zero turn
   / reverse issues on my toro 724-z zero turn #1
firebirdfan78
satoh beaver
The mower works great going forward,but going backwards isnt very good.its ok on flat groung or going backwardd down hill, but it will not move if im trying to go backward up any kind of incline.i just boight it and have no clue about them. Does anyone have any info of what possible issues may be.
   / reverse issues on my toro 724-z zero turn #2
Have you checked the fluid level and condition? Could just be a linkage thing.
   / reverse issues on my toro 724-z zero turn #3
I've had 2 Toro Z Masters, and I have never experienced this type of problem. Normally, if the machine won't move, it won't move in either direction (assuming the problem is with the hydro pumps. wheel motors, or hydro fluid). It may be the linkage controls need adjusting or is it possible your wheels are just spinning since you can back on flat ground and downhill? I can easily lose traction and over spin my tires with my Toro on a hill and have to be fairly gentle with the control levers to prevent that.
Is this machine new? If so, a call to the dealer should get you on the road to recovery. If its used I'd talk to seller to see if he was having any problems like that.
PH
   / reverse issues on my toro 724-z zero turn #4
The dampners or struts on the hydro sticks (levers) could be worn out.. Is the machine new or used??? If used, how many hours?
   / reverse issues on my toro 724-z zero turn #5
When it won't move in reverse, have you looked to see if the wheels are spinning? Or maybe you're not as dumb as I was.:laughing: Fortunately, I found that was the problem before I talked to the dealer about it.
2016 CHEVROLET 3500HD SERVICE TRUCK (A54756)
2016 CHEVROLET...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
2013 Chevrolet 3500HD MPV Service Truck (A52377)
2013 Chevrolet...
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
