Reverse hesitates
/ Reverse hesitates #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
HI,
My JD 4310 has a problem. It started this Winter. When I step on my reverse pedal, nothing happens. I have to step on the reverse pedal a few times before reverse will kick in and start moving. Sometimes the reverse "jumps" into moving in reverse, other times it does it normally, a gradual reverse motion.
Any idea what the problem is?
FredSG
/ Reverse hesitates #2
Lubricate, grease/oil the linkage underneath the deck. Move it while doing this. Should also do a visual inspection of the bottom side to ensure all is as it should be.
/ Reverse hesitates
My 4310 is the utility tractor . . . could you be more specific as to what to lubricate and what else to check on?
Thanks for your reply.
FredSG
/ Reverse hesitates #4
You should find some grease nipples and oil any place there are moving parts.
I have a jd4200 which is probably a little different.
2023 Maybridge B7D 6ft. Chain Harrow Tractor Attachment (A66734)
2023 Maybridge B7D...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A66734)
2025 Kivel Quick...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A69167)
2016 INTERNATIONAL...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A67148)
2019 RAM 5500 4X4...
2023 CATERPILLAR 299D3 SKID STEER (A65056)
2023 CATERPILLAR...
