Reverse hesitates
   / Reverse hesitates #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
HI,
My JD 4310 has a problem. It started this Winter. When I step on my reverse pedal, nothing happens. I have to step on the reverse pedal a few times before reverse will kick in and start moving. Sometimes the reverse "jumps" into moving in reverse, other times it does it normally, a gradual reverse motion.
Any idea what the problem is?
FredSG
   / Reverse hesitates #2
Lubricate, grease/oil the linkage underneath the deck. Move it while doing this. Should also do a visual inspection of the bottom side to ensure all is as it should be.
   / Reverse hesitates
My 4310 is the utility tractor . . . could you be more specific as to what to lubricate and what else to check on?
Thanks for your reply.
FredSG
   / Reverse hesitates #4
You should find some grease nipples and oil any place there are moving parts.
I have a jd4200 which is probably a little different.
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
2016 Ford F-550 Enclosed Service Truck (A51692)
2016 Ford F-550...
2024 TOFT 1550 Hydraulic Breaker (A53117)
2024 TOFT 1550...
2010 American LaFrance Thermoplastic Striping Truck (A52377)
2010 American...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
