Mowing reversable finnish mower?
   / reversable finnish mower? #1
bc realtor
Vancouver Island BC
Antonio Carrero TTR4400
I have just aquired my first tractor. I want to put a finishing mower on it ,But the tractor is an Antonio Carrero TTR4400. The whole machine is reversable, I thought it would be better for steering and visability if I could drive with the mower first. All the finish mowers I have seen are rear discharge. I was thinking a side discharge would work better? Anyone have any thoughts or experience with this matter?
   / reversable finnish mower? #2
As long as the mower is traveling in the direction it was designed to go, things work out. Running the mower backwards drives the discharge material against the whirlwind vortex. That will be a problem. The deck usually clogs up.
I guess that it would have to be a specialty type of mower then$$$$$?
   / reversable finnish mower? #4
Very cool machine. I like your hedge trimmer.
There are a lot of front mount mowers out there. Kubota F-series are one, and I think that the JD model #'s also start with F.
You could probably get a deck for one of them, and modify it to use with your machine.
   / reversable finnish mower? #5
Nice Tractor. Does the seat/steering wheel platform turn around to the other direction??
   / reversable finnish mower? #7
you should be able to get a side discharge one, reverse the mounting brackets and the gearbox and mount it on your tractor (assuming that the PTO shaft spins the the same direction)
Below is an example, the only problem is that it is a rear discharge model, but the idea is the same.
Aaron Z
   / reversable finnish mower? #8
I got just the ticket. It's a 60 inch deck that ran out in front of a yazoo when its life started.
It has a side discharge and looks just like a finish mower except it's mowing backwards and they do a very good job.
   / reversable finnish mower? #9
Nightrain1
What state do you live in?
   / reversable finnish mower? #10
Illinois, about an hours drive from St Louis
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
STORAGE FEES (A52577)
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2021 Toyota Corolla LE (A50324)
2021 Toyota...
International Tractor w/Belly Mower (A50774)
International...
