RETURN VALVE ? MASSEY F 135
   / RETURN VALVE ? MASSEY F 135 #1
GREENBOY
Hello All,
I have a MASSEY FERGUSON 135 and have spent out on a 3 point hydraulic log splitter. I have only one hydraulic valve / port set up, and I have to attach the return hose to the tractor. I have been told that it is to be attached in the hole on the right - now I am sorry as this is to most a simple task but my engine has been coated/protected in a grey paint and I tried loosening the hex screw thread but it didnt shift at all - i dont want to over exert and ruin the socket, any ideas how i can remove it and if it is the right hole. I have attached a photo of the left hand side of the tractor under the seat - the screw thread I am looking to remove is the one on the far right. Is this the right one for the return and how do I loosen it , also any tips as this is my first experience with hydraulics:eek:
Thanks in advance
   / RETURN VALVE ? MASSEY F 135 #2
Welcome to TBN:D
Let me first state that I am not familiar with your machine, but if you have only ONE valve that has only ONE port, then I am willing to bet it is for a SA (single acting, one hose) cylinder like used on older plows and such where gravity lowers them. I suspect you will have problems trying to operate a DA (dual acting, two hoses) cylinder that is on the splitter.
HI KENNYD - Thanks for replying.
Sorry there is one port which is connected to the pipe that runs from the block to the right where there is a quick release female hose end, there is also another one (and maybee more) to the right, this is the one that need to be un-screwed, i just wonder if there was a special tool required as it seems to be stuck fast, maybee I should have posted this onto the MASSEY section on TBN:confused:
hi - i have posted this on the MASSEY OWNERS forum to save time (sorry didnt think of it at first:eek: )
2002 Ford E-150 Passenger Van (A51692)
2002 Ford E-150...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
40 ft. Shipping Container (A53117)
40 ft. Shipping...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
