Return to center
/ Return to center #1
ParkerFly
Can someone explain to me how you make a hydraulic cylinder return to center? For example, you pull a lever and the cylinder extends, but when you let off that lever it springs back to neutral and the cylinder automatically retracts back to its center position.
I appreciate any insight into this. Thank you,
Justin
/ Return to center #2
That would require some type of special valve-probably not commonly available.
Can you please tell us the application you need it for? We may have other options/suggestions.
/ Return to center #3
Need more data, but I will give you some ideas. Basic centering could be done with an electric valve and switches. Then you have sensors like lasers, magnetic, pressure. Are you considering a double rod cylinder, like in boat motor steering. How about Power steering like on a car.
On my Power-Trac, I have a cable that controls my hydraulic transmission. It goes through an assembly called a Hydroback, which keeps the lever centered so the machine does not move in neutral. When I push on the pedal, the transmission shifts one way, and when I press the other side of the pedal, it shifts the other way. When I am not pushing the pedal, the valve is in neutral. The Hydroback has opposing springs to keep the cable centered within a certain range.
Can some of you PT owners explain how the hydraulic shift for your transmission works. It must work something like a spring loaded valve.
/ Return to center
It's currently in operation on a tractor pulling sled. The pan under it pivots to steer the sled. It is on an electric solenoid and returns to center (straight) when you let off the switch. I was just curious if anyone knew how it was doing that. Thanks.
/ Return to center #5
Are you talking about the cylinder returning to center, or the pan returning to center?
/ Return to center
The cylinder returning to center. When it returns to center the pan is centered, and that's what made me wonder how you can make a cylinder return to center like that.
/ Return to center #7
Short, expensive answer, an LVDT. Linear variable displacement transformer. Usually computer controlled. Off the end of the cylinder is a spool that goes through a coil. The coil sends a signal to the computer and the computer would fire the motor/pump and electronically spool the valve to return the cylinder to it's predetermined point. Could be center, fully stroked, retracted, or anywhere inbetween. You can calibrate it to wherever you need. A simpler way may be to use micro switches to trigger an indicator light or shut the motor off when the cylinder is where you want it.
/ Return to center #8
/ Return to center
It's just a standard cylinder. Cross 4" bore 8" (I think) stroke. By return to center, I mean that the cylinder returns to the center of its stroke (extended 4") when you let off the button to cycle it.
/ Return to center #10
That data almost tells you that they use electric valves and limit switches and relays to center the pan.
/ Return to center
I'll try to snap some pictures of the setup later today if I get a chance and see if you guys can make some sense of it. I've never seen a setup that works like it does and I'm just trying to understand everything on it
/ Return to center #12
Are you the one that is trying to make a mini version of the drag sled?
/ Return to center #14
Who is the manufacturer of the sled? Try and obtain the service manual for the unit.
/ Return to center
Unfortunately it's an older home made unit. Here is a picture of it, and I will try to get more of the hydraulic system later today.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
Case skid steer wheels and tires (A63689)
Case skid steer...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
UNUSED LANDHONOR RIGGING/BINDING CHAIN SUSPENSION (A64281)
UNUSED LANDHONOR...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
