Loader Return Line placement
/ Return Line placement #1
hazmatguy
Conroe, TX
Yanmar 3110
I am up grading the parts on my front end loader.
I have a prince control valve that requires three lines.
Power, Power beyond, and Tank
Without the Tank line hook up, the loader will not work.
Without Power beyond the Power steering and 3pt lift will not work.
My question is where to I plumb the to tank line. The old valve did not have the power beyond port.
Thanks
Hazmatguy.
/ Return Line placement #2
What Model tractor? and might need to describe better on how you routed the lines? on my 1700 I had to remove the dipstick from the tank and adapt the dump line back into there,
It is a 3110.
I have the line from the pump to the control valve, line out from the control valve goes to the power steering then from the power steering to the 3pt hitch.
I was looking at the dip stick at a possibility. Just did not know if there was another location that could be used for a "to the tank" line.
Thanks
Hazmatguy
2014 FREIGHTLINER M2 FLATBED (A67148)
2014 FREIGHTLINER...
2013 Caterpillar Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
2013 Caterpillar...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2021 Norwood Towable Lumber Pro HD 36 V2 S/A Towable Bandsaw Sawmill (A64194)
2021 Norwood...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
