Loader Return Line placement
   / Return Line placement #1
hazmatguy
Conroe, TX
Yanmar 3110
I am up grading the parts on my front end loader.
I have a prince control valve that requires three lines.
Power, Power beyond, and Tank
Without the Tank line hook up, the loader will not work.
Without Power beyond the Power steering and 3pt lift will not work.
My question is where to I plumb the to tank line. The old valve did not have the power beyond port.
Hazmatguy.
   / Return Line placement #2
What Model tractor? and might need to describe better on how you routed the lines? on my 1700 I had to remove the dipstick from the tank and adapt the dump line back into there,
It is a 3110.
I have the line from the pump to the control valve, line out from the control valve goes to the power steering then from the power steering to the 3pt hitch.
I was looking at the dip stick at a possibility. Just did not know if there was another location that could be used for a "to the tank" line.
Hazmatguy
GENERAC GP6500 GENERATOR (A50854)
GENERAC GP6500...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
Delta Consolidated Fuel Tank 48000 (A51039)
Delta Consolidated...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
2006 CMI C125-1 Ride-On Forestry Mulcher (A49461)
2006 CMI C125-1...
