Retrofitting air ride seat to 1025R
   / Retrofitting air ride seat to 1025R #1
Aviatndude
Danville, IN
John Deere 1025
Anyone ever retro fit a 102x with an better seat? Air ride or mechanical? Mine factory one broke and I am considering options.
   / Retrofitting air ride seat to 1025R #2
:welcome: to TBN
Any explanation of how and/or why it broke?
No, I am not sure why it broke. One of the parallel arms is snapped. I checked and I just need the seat base, but apparently they have changed the seat base mechanical bits, because they are requiring buying the entire assembly, sprints and all. At approx 400 bucks I am wondering if I can go to a better suspension (I am 215 which is at the top end of the weight rating for the seat.) I have the bigger springs, but more travel and air ride sound good, and my experience with bigger tractors is air ride is nice. My first option is to weld it back together, but ...
   / Retrofitting air ride seat to 1025R #4
The seat and the gentle start of the PTO were the only bright spots in the lemony 1025R that I had. I'd just replace in kind.
Ralph
   / Retrofitting air ride seat to 1025R #5
Do you have a flat platform for an air ride seat to mount? Bolt pattern would be 10.25" side to side at the base for a standard base, that is if you bought a Grammer base.
I would imagine that you would need everything, base and the seat which will be over $1k.
Attached is a Grammer spec sheet for the MSG95. They do make a narrow and wide base versions as well. View attachment 632594
thanks gents. I got the "suspension" off and ended up cutting one of the parallel arms to get enough freedom to work the frozen joints (all 8 bushings) loose. Neighbor is pro welder and plans to TIG it back together this week. So I have time to do the conversion right... Hard to believe that as much as I use that thing the seat suspension basically tried to weld itself together. Deere has a new part number preventing buying just the suspension, you even have to buy the seat belt mount bar. 611 hrs in 4 years- it doesn't sit long. New ones (tractors or seats) are not really any different than my 2015?
   / Retrofitting air ride seat to 1025R #9
I have been thinking of a better seat for my 4110. I know Kenny in the past purchased a replacement seat but I believe mounting problems prevented installation. I have space on the sides but height of the seat from the base may become a problem. I am still looking but haven't come up with the best manufactured system. I'm aware they may be pricey but divided by the hours of use it will be worth the value.
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
Ditch Witch R 40 (A52384)
Ditch Witch R 40...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
