retro fit John deere 7 to kubota b2601
   / retro fit John deere 7 to kubota b2601 #1
Kubota Polaris
granville ny
kubota b2601
I have a few questions. My dealer tells me I need to figure out if the Backhoe is open or closed center. Does anyone know? They say I cannot use an open center valve. Also does anyone know which ports in the valve body I should attach the hydraulic fittings?
   / retro fit John deere 7 to kubota b2601 #2
I have a #7 on a Deere 790. I believe it's open center but I only say that because it hooks into my Power Beyond circuit and I was warned to not leave the PB circuit disconnected. That tells me fluid always flows which I believe is open center.
Hope this helps and welcome to TBN!
Thanks for the Welcome and the info. I really hope someone can help with a picture of the valve ports I should use on the tractor if i can make this work. Also does anyone know if the open valve issue could be overcome somehow?
   / retro fit John deere 7 to kubota b2601 #4
Show a picture of your hyd block. It should be under the right floor board.
   / retro fit John deere 7 to kubota b2601 #5
Are you sure they said not to use an open center valve? The 2601 uses an open center hydraulic system, there is no hydraulic block like on some tractors as the loader valve is integrated. I guess you could consider the loader valve the hyd block.
   / retro fit John deere 7 to kubota b2601 #6
If you have the built in loader valve, you will have to cut the line going to the 3pt and insert the new valve using compression fittings.
Install a male and a female QD and just plug in the BH when needed. You will not need the 3pt system.
When not using the BH, couple the QD together.
If your BH valve is convertible, make it so it is open center with PB adapter installed.
   / retro fit John deere 7 to kubota b2601 #7
If you don't want to cut the line you can replace it with adapter fittings and hoses, I haven't checked the 2601 yet but it appears to use the same valve for the loader and fitting on the transaxle for the 3pt as the B2x20 series.
If that's the case then the banjo fitting on the valve can be replaced with a SAE 8 o-ring fitting, and the 3pt fitting on the transaxle uses a 3/8 BSPP.
   / retro fit John deere 7 to kubota b2601 #8
Here's pictures from my B2620 after I added rear remotes, you'll use the same connection for a backhoe.
The loader valve picture won't load.
   / retro fit John deere 7 to kubota b2601 #9
Found a picture of the loader valve
I used a sae8 to jic6 90* to connect the hose
   / retro fit John deere 7 to kubota b2601 #10
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
Electric Concrete Mixer (A51573)
Electric Concrete...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2021 Ford F250 4X4 Service Truck (A52377)
2021 Ford F250 4X4...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A51573)
New/Unused AGT...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
