RETIRED
   / RETIRED #1
R J WEPPNER
I wish to cut rubber conveyor belt.What is the best lub to use?
John WEPPNER AUSTRALIA
   / RETIRED #2
It depends what you are cutting it with. The best lube for rubber in many cases is soapy water. Sometimes lube can work against you. If you are using a saw the lube will cause the saw to get pinched. We make conveyors were I work. Several hundred miles of conveyor every year. We cut all the conveyor belt with utility knives with no lube. These are thin belts. 3/16" or less in thickness.
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
