Retired Mechanic
/ Retired Mechanic #1
markmechanic
Dalton, Ga.
Simplicity Broadmoor
I am a retired mechanic, enjoy helping others resolving problems with their equipment. I am currently helping a friend with his 1997 2wd 4630 New Holland Tractor, need wiring diagram.
/ Retired Mechanic #2
Well welcome we can certainly use you here. What did you work on?
/ Retired Mechanic #4
Welcome from Wisconsin, there are a lot of people here that have Questions regarding there equipment.
/ Retired Mechanic
Knowledge is information, wisdom is discernment- knowing right from wrong, therefore giving & obtaining correct information is most necessary. Having year, make, model, as well as all numbers from equipment & engines are a must when assisting folks.
/ Retired Mechanic #7
Welcome from Connecticut, enjoy your retirement, a knowledgable problem resolver I'm sure can be kept occupied here.
<CFAllocator 0x1472a900 [0x38522710]>{info = 0x145b1e30}
/ Retired Mechanic #8
Welcome! Want a problem to ponder? I have one that has me a bit baffled.
/ Retired Mechanic #9
Welcome to TBN Mark. Now that you have retired, you may be busier than ever. I am also retired. If I could afford it< I would hire two guys to help me keep up! :dance1::drink:
/ Retired Mechanic #11
HI I AM ROBERT AND HAVE A MASSEY FERGUSON 130 1970 MODEL AND THE PTO SHIFTER WON'T MOVE
/ Retired Mechanic #13
LEVER WON'T MOVE AT ALL OWNER BEFORE ME HAD TO FORCE THE LEVER WITH A BLOW WITH A POLE
/ Retired Mechanic
Massey Ferguson MF25 MF130 Tractor I T Service Shop Manual Very Good | eBay First purchase a shop repair manual so you can familiarize yourself with troubleshooting & repair of your tractor. Shop repair manuals are loaded with necessary information & steps to follow so you can make a proper repair verses guessing as you go along. Whether a person purchases a new or used tractor and intends on making their own repairs, a shop manual is a must have.
Massey Ferguson 130 Tractor Manuals | Jensales - World's Finest Manuals
PTO Coupler For Massey Ferguson Tractors Not sure if this is part you need that's why i suggested purchasing manual.
Parts for Massey Ferguson 130 tractors | All States Ag Parts
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
300 GALLON HYD OIL TANK (A64280)
300 GALLON HYD OIL...
211298 (A62131)
211298 (A62131)
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
POLY WRAP CORES (A63291)
POLY WRAP CORES...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
