Retired in Panama
/ Retired in Panama #21
Washer fluid is what I use and is not supposed to corrode rims like maybe water would. Is it possible to switch the rear tires to opposite sides while keeping the tread in the correct direction? This could give you a wider stance depending how there made.
Sent from the mountains
/ Retired in Panama
Thanks for the washer fluid suggestion. Do you dilute it, or use it straight?
Re switching sides, the wheel flange is fairly central to the hub so switching sides wouldn't make much difference. Also, I'm not sure I want to put too much extra bending moment on the axles. I'll stick with the 3" spacers.
/ Retired in Panama #23
I just use straight washer fluid. In Ky I have freezing temps in winter though. Rimguard is another option but expensive. It's much heavier than water
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A61572)
2025 Kivel Fork...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
Kubota Z232 (A60462)
LINCOLN RANGER 8 PORTABLE WELDER (A63291)
LINCOLN RANGER 8...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
Claas Lexion 500 Series Manuals (A63117)
Claas Lexion 500...
