Rethinking Kioti products
Status
Not open for further replies.
   / Rethinking Kioti products #71
Regarding the lows hours on the tractor. Before I bought my CT225 I had looked at a 2012 Bobcat CT122 with a backhoe. It had 25 hours on it. The guy owned a dozen tractors and really never used the small CT122. Older low hour tractors are out there -- but are rare.
   / Rethinking Kioti products #72
My question is how on earth can you only put 17 hours on tractor in 4 years???? That's not even five hours a year. I can do five hours in good day of work. Maybe hour meter is busted as well?
1) illness interrupted plans
2) bought for snow removal south of Mason Dixon line
3) used exclusively to maintain 10ft x20ft vegetable garden
4) owner got a job in Saudi Arabia right after purchase
5) owner phobic about large orange objects
6) wife hid keys after excessive use on first day
7) owner forgot where he parked it
Agree such low hours are rare but I bet there are a few others like this out there. Certainly 25hrs a year is not so unusual.
   / Rethinking Kioti products #73
I'm still unclear on what's going on.
This tractor never actually went to the dealer to be looked at. Is that correct?
The dealer only gave his advice that he felt it may be in the wiring, but never saw the tractor. Is that correct ?
Then the owner calls Kioti corporate expecting advice on his problem with a few dash lights not working. Is that correct?
Maybe I'm reading it wrong.
   / Rethinking Kioti products #74
That is what I understood also. So if you are wrong, we both are.:)
   / Rethinking Kioti products #75
Maybe I'm in the minority with this perspective, but I'd say that 17 hours over the course of 4 years could constitute abuse. In my opinion, sitting around not being used is not helpful for equipment. Maybe old purely mechanical stuff doesn't suffer as much, but a modern deluxe model tractor like we're discussing here has lots of electronics. When stuff doesn't get used it deteriorates. The problem could be from corrosion, or possibly from mice or other varmints chewing wires. If you don't use the machine regularly, you should inspect it for mouse activity before firing it up.
I hope this isn't taken as rude, but perhaps the OP would be better served by renting a tractor for the occasional need. After only 17 hours in 4 years, it's probably safe to assume that the rings aren't even seated yet. Has this machine ever been run long enough to get the oil hot enough to remove condensation? Oil should really be changed annually on tractors (with some exceptions I'm sure), despite the amount of hours on the clock. So, the OP should have completed at least 3 oil changes by now. Also, a machine that's used in this manner will probably draw some scrutiny during resale. I'd probably rather buy a 10 year old machine with 1000 hours than one with 40 unless there was a darned good reason for it to be that way and proper steps were taken to store it.
   / Rethinking Kioti products #76
How many of you would be upset and start a thread like this about your new truck? Would you be going to a dealer to get it fixed, or would you call the manufacturer and expect their help directly?
This thread seem very strange to me, and there must be much more to the story that we are hearing.
If that is the case I think this post needs to be brought up again.
   / Rethinking Kioti products #77
17hrs in 4 years, modules tested good in other units. Screams out to me as critter chewed wiring. Heck, I leave anything parked for more than a week and it seems like I have to shake the critters out of it. Maybe I just need some cats. ....
   / Rethinking Kioti products #78
Dealer told the OP he felt it could be a wiring issue since the others checked out.
OP refused to believe it or check it out from what I could see..
   / Rethinking Kioti products #79
Yep, this sounds feasible. I have poison and glue pads all around my equipment for this reason. They will ruin anything they don't care if it is under warranty or not.
   / Rethinking Kioti products #80
Guys im not bashing Kioti like i said in my post this is my second unit but, i will pose a test for you who may have doubt try to contact melissa waters at Kioti hq in north carolina and wait for them to call you back please go ahead i'll wait............. i bet you no one called back. like i posted im dealing with the usa #1 dealer of Kioti and to me i feel like everything should work properly on this tractor i feel its at safety issue if my son hit the forward pedal and it rolls because you cant see what you are in could be disastrous. as i posted everything was fine when i found out it was not working i took off the potentionmeter tested it and also put it on a working Kioti and the dash lights worked i then removed the cruse unit and did the same thing and it was also working then i hooked the dash up to a new Kioti and it to works fine now im frustrated i'm running out of thing to test and don't seem to be getting help from Kioti no one wants to admit thay had cruse moduel problems or ignition issues whats a fellow have to do? i love my tractor but, never thought i would have problems just speaking to someone i'm pretty knowledgeable about mechanical stuff but this one has got my head hurting..
Poor Melissa, her phone is probably getting burned up by all of you accepting this test. This poor OP will probably not post on TBN again. I wonder if he is really Trace Adkins or was just smoking something when he posted that about TA?
Status
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2014 John Deere 5055E (A53317)
2014 John Deere...
2025 Newrick JC25 Mini Wheel Loader Skid Steer (A55851)
2025 Newrick JC25...
2014 DODGE RAM 5500 HEAVY DUTY UTILITY TRUCK (A57192)
2014 DODGE RAM...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
1994 Generac Olympian 3054 125kVA 3-Phase Diesel Generator (A55851)
1994 Generac...
