Results from my 7500hst
   / Results from my 7500hst #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
I let my machine warm up for about 5 minutes before each use and kicked it into to full throttle after 10 minutes with a RPM reading of a hair under 2800 with no load. Mowed for 1 hour and did the same with the same RPM's. I have a non-contact infrared thermometer and did a reading on the engine block just after I shut it off with a 174 degree F. The transmission was 146 degrees F on both sides. 13.4 hours total on machine. The outside temp was around 76 degrees F. Anybody else have simular readings?
   / Results from my 7500hst #2
Thanks for posting this info. I have been having a problem with my tractor and do not have actual temp degree readings..., but was waiting for another B7500HST owner to post their rpm readings. Being a first time tractor owner/operator I find it interesting that they (at least our particular tractors) don't really have much power to spare above PTO speed. As you may have read in my post about overheating, losing a few hundred rpms when you are barely above PTO speed at full throttle can be quite noticeable.
Thanks again, at least now I know that my tractor is up to speed at least while running cool.
Fred
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
Unused 2025 Electric Cart (A51694)
Unused 2025...
2004 Ford F-250 Service Truck (A53422)
2004 Ford F-250...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2008 Chevrolet Express 2500 Ambulance (A51692)
2008 Chevrolet...
