Restricting the top link… advice?
   / Restricting the top link… advice? #1
S854
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
I know…I’m beating a dead horse…
I see many MANY threads referring to placing a restriction in the line… what I can’t find is the “5 buck” orifice every thread refers to…
Quite a few suppliers sell a simple, inline orifice (which would be my preference) but I’ve seen them as high a $75 for a 1/2” NPT orifice… outrageous!
I’ve check Surplus Center (recommended in many threads)… all they currently carry are the adjustable style… I don’t need that ability…
So… I’ve found a “restricted swivel”, available through ACE, but I’m wondering if it does essentially the same thing as a “one piece orifice”… I don’t need the swivel as my restriction will be screwed directly into the male part of my quick connect…
   / Restricting the top link… advice? #2
Its fairly easy to convert an existing fitting to restricted if you or a friend have a metal lathe. Its a matter of making a press fit plug drilled to about 1/32" diameter or slightly larger depending on cylinder bore size. Probably could be just a slip fit if it is captured when the fitting is assembled.
Unfortunately I don’t have access to a metal lathe… one would be handy for so many applications…
Yes on the Apache… albeit with a 1/2” thread…
Depending on the supplier there’s either a 1/32” or 1/16” restriction… which one did you get?
   / Restricting the top link… advice? #5
1/2" hose and fittings are larger than you need for a hydraulic top link. 1/4" would be fine.
If yours has reducers after the quick connects to get the standard 1/2" ag connector down to a more reasonable size hose, I'd put the restrictor in the smaller diameter part after the reducers.
   / Restricting the top link… advice? #6
I use the 1/16 I also have some that are jic to jic I found them on eBay a while ago. All my hoses are 1/4: my tractor max flow is 7.5 gpm so 1/4 is fine for everything and cheaper.
I had the dealer install the top n tilt prior to delivery… they used 3/8 hoses with a 1/2” male end…
   / Restricting the top link… advice? #8
Taixin Hydraulic High Pressure Ball Valve 1/2'' NPT 5800PSI Hydraulic Valve Shut-Off KHB Hydraulic Ball Valve https://a.co/d/itaXUNw
   / Restricting the top link… advice? #10
3/8 is fine. If it was me I'd put the restrictor in the 3/8 hose just to reduce the weight and bulk of the stack of adaptors and fittings.
A ball valve is the wrong fitting for this as it does not allow for fine control of the flow. Either a fixed orifice restrictor or a flow control valve like 3/8 NPT 8 GPM Prince WFC-600 In-Line Flow Control | Prince Mfg | Brands | www.surpluscenter.com
That one is one way which may or may not be right, depending on what's needed. I have one on my loader to reduce bucket flop and three on my backhoe to make up for valves with poor control.
This one is two way: 3/8 NPT 8 GPM Needle Valve Wolverine by Prince Mfg WNV-600 | Wolverine by Prince Mfg | Brands | www.surpluscenter.com
2005 Featherlite Double Deck Stock Trailer (A50514)
2005 Featherlite...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
International 1086 Cab Tractor 2wd (A52128)
International 1086...
New JCT 7' Double Skidloader Grapple Bucket (A50774)
New JCT 7' Double...
PALLET OF WALL PACKS (A51244)
PALLET OF WALL...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
