restoring Woods BH750-2
   / restoring Woods BH750-2 #1
metalcaster
SW Michigan
Mahindra 1538
picked up a used BH750 from a local dealer last month. Before I started using it I though I'd pull it apart, blast it check it for cracks, repaint and assemble. It was operating when I received it, but it did look as though it had sat around awhile. Here are some pictures after blasting. WP_20141206_001.jpgWP_20141206_002.jpgWP_20141206_003.jpgWP_20141206_004.jpgWP_20141206_005.jpg
   / restoring Woods BH750-2 #2
picked up a used BH750 from a local dealer last month. Before I started using it I though I'd pull it apart, blast it check it for cracks, repaint and assemble. It was operating when I received it, but it did look as though it had sat around awhile. Here are some pictures after blasting.<img src="http://www.tractorbynet.com/forums/files/build-yourself/404405-restoring-woods-bh750-2-a-wp_20141206_001-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/404406-restoring-woods-bh750-2-a-wp_20141206_002-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/404407-restoring-woods-bh750-2-a-wp_20141206_003-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/404408-restoring-woods-bh750-2-a-wp_20141206_004-jpg"/><img src="http://www.tractorbynet.com/forums/files/build-yourself/404409-restoring-woods-bh750-2-a-wp_20141206_005-jpg"/>
Looks good! Now hurry and prime it before it rusts.
Sent from my iPhone 5s 64Gb using TractorByNet
Primed it with Sherwin Williams shop coat lacquer primer then a couple coats of an oil based green. Machined all new pivot pins and put on a couple of new bumpers. Woods was really helpful by sending a pdf of the owners manual. Helped with the reassembly immensely. Put it on the tractor yesterday and got it all adjusted. WP_20141209_005.jpgWP_20150413_006.jpgWP_20150107_004.jpgWP_20150107_003.jpgWP_20150107_002.jpgWP_20150105_003.jpgWP_20150105_002.jpgWP_20141209_008.jpgWP_20141209_007.jpgWP_20141209_006.jpgWP_20150413_007.jpg
ran it a bit today, it will take some practice.
   / restoring Woods BH750-2 #4
I picked up a BH750-3 last fall in very good shape. I did not take it apart like you did. I did pull and inspect all the pins, replaced grease fittings, Fabbed my own sub frame brackets, fluid and filter changed. I'm thinking about buying a new safety decal package and repainting but not going to the extent you did.
You did a very nice job.
Do you know if you can buy rubber pads for the stabilizer feet. I didn't see them listed in the parts manual.
   / restoring Woods BH750-2 #5
Nice job!
I have a 650. You'll be happy with it, great little 'hoe.
   / restoring Woods BH750-2 #6
I didn't notice the joystick cover in any of your pics. (See arrow in my 3rd pic)
Was it missing when you bought yours?
Yes the control cover is missing. I didn't know that there were rubber pads on the stabilizer feet as there wasn't any evidence of anything being there upon purchase. I probably won't put anything on them for now.
I dug a little with it the other day on a sassafras stump. I'll have to dig a pretty big hole to get it out so I am making a root hook to put in place of the bucket. Then maybe by just hooking all of the roots around the perimeter I can just push it over?
   / restoring Woods BH750-2 #9
I have the operators manual (w/parts list) but it does not list rubber pads. The feet have 2 holes in them for pads to mount but don't know where to get them. I don't know of any other reason for the 2 holes on the feet except for rubber pads.
In case you want to order the console cover the one for the 750-2 is part# 33351. The 650-3 & 750-3 have a different part#.
The complete decal set for yours is part# 33424 or just the safety decal set is #32330.
I've decided to sell this back hoe and get a little larger one designed to fit my Mahindra. Located 49067 for anyone that wants to look at it.
2012 Dodge Charger Passenger Car (A51694)
2012 Dodge Charger...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51248)
KNOW BEFORE YOU...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2010 JOHN DEERE 648H SKIDDER (A51246)
2010 JOHN DEERE...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
