Restoring Lincoln Tombstone
   / Restoring Lincoln Tombstone #11
I would think the synthetic grease would be a good choice as it is liable to be a hi temp grease. I would think that would be just what you would want. It sounds like the OP's machine sure could use some grease on the contacts as they are so hard to switch.
James K0UA
There is no problem with the potential conductivity of the grease?
   / Restoring Lincoln Tombstone #12
Well I would not use anything with Moly in it.. the maximum OCV is 80 volts. I would think the breakdown voltage of this synthetic grease would be a lot higher than that. I think it would be good to use.
James K0UA
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55218)
2023 NEW HOLLAND...
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A54865)
Vermeer D16X20A...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
