Restoring a 1939 Ford 9N
   / Restoring a 1939 Ford 9N #1
Dragonslayer
McDonough, Georgia
Kubota BX 2230 D, 1939 Ford 9N
Recently I made a package deal on two tractors and a 4' Bush hog. One of the tractors is a 1939 Ford 9N that last ran a year ago. It turns over but won't crank. I believe the starting point is to clean out the gas tank, replace the fuel filter bowl and rebuild or replace the carburetor. My plan is to get it running right and either use it for bush hogging or restore it all pretty for resale including a repaint to factory colors.
Any help and advice along the way will be greatly appreciated.
   / Restoring a 1939 Ford 9N #2
Do a compression test, and check the points too.
Please post lots of pics as you go!
   / Restoring a 1939 Ford 9N #3
Don't know if you know this already or not, but worth mentioning in case you don't.... Having hung around TBN for 17 years, I've read about 9Ns and brush hogs. And a friend of mine has one and has mentioned this. I can't recall for sure, but I think the 9N does not have a live PTO, so when you clutch, the PTO stops spinning. Conversely, if you slow down, the blades of the brush hog spinning will keep pushing the tractor forward unexpectedly even if you clutch, because the PTO is connected to the tranny. Clutching just disconnected the engine, not the PTO.
At least, that's the way I recall reading it. Never had one, so can't confirm.
Also, investigate an overrunning clutch for the PTO shaft. That should keep the implement from pushing the tractor, I think, but again, am not sure.
   / Restoring a 1939 Ford 9N #4
As for the gas... give it a pop of carb cleaner (or staring fluid) while cranking and see if there's fire before tearing into the fuel system.
   / Restoring a 1939 Ford 9N #5
A PTO overrunning clutch is available from Agri-Supply for $29.99.
"Don't leave home (very dangerous) without it".
Agri-Supply is a GREAT company to deal with!
   / Restoring a 1939 Ford 9N #6
Many people think they have a '39 but most have a later model. there was a lot of changes made that first year. Best to check the serial number on the flat shot just behind the oil filter near the head. Post some photos if you can. Here is one of my '39's for comparison.
   / Restoring a 1939 Ford 9N #7
I can not say strongly enough that in my opinion an N tractor is an extremely poor choice for either bush hogging or restoration. They're terrible for mowing because they're geared too high and don't have live hydraulics. If you restore it and paint it you'll be pretty hard pressed to get even your money back, much less turn a profit.
Best thing would be to get it running and sell it as is. Just my thoughts.
   / Restoring a 1939 Ford 9N #8
What he said :thumbsup:
Unless you have a special attachment to it let it ride unless it really is a all aluminium hood 39 then in that case send me a pm and we will talk
   / Restoring a 1939 Ford 9N #9
"It turns over but won't crank"
How about when you crank it, does it turn over? :confused3:
John Deere 6175M (A50120)
John Deere 6175M...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
Year: 2008 (miles exempt on title) Make: Nissan Model: Sentra Vehicle Type: Passenger Car Mileage: (A51694)
Year: 2008 (miles...
