Restarting My '70 Nova Project
   / Restarting My '70 Nova Project
Looking great, and nice to see it getting closer and closer to the finish line. Do you have to get it re-appraised now that you have completely restored this beautiful car and significantly increased the value of it ?
Yes, once it's finished. I'm going to get it re-appraised and re-insure for actual value.
Wait, does a sleeper like that beauty (currently lol) need any more chrome and striping, hood louvers, vinyl top/two-tone, fox tail, 6' CB whip on rear bumper (BTDT), running boards, class II hitch, extendable AM/FM antenna with yellow tennis ball or Real-Lemon container on it to help locate it in a parking lot .. to LOOK just awesome? :oops:
Just that I think a lot of (more) dress might expect perf to match from many. Imagine smoking a pair of used tires down to the belts at a car show and few saw it coming (well, exhaust note/rumble at idle) from a car that looks so handsomely stock. (hp vs stock tire size? lol))
Apologies for my taste for body-color trim and a humble appearance and the rant. btw, the tires could have been mounted 'reversed' and not have to show that gaudy white writing on the sidewalls. :ROFLMAO:
Not sure I appreciate your taste in accessories, I'm of the more subtle, don't show all your cards kind of guy. ;)
I tried to find some 434 emblems to replace the 350 emblems, but no one makes them. I guess 427 ones would be a little more honest, but then everyone would think it had a big block. I was thinking I might be able to 3D print them though. Hmmmm.
The tires are 215R14s in the front and 245R14s in the rear, on 7" wide rims.
I took the hood louvers off until the stripes are put on. The AM/FM antenna will be in the windshield, and I never had a CB in any of my cars back then, but I did have one of the early Craig (I think) 8 track players and a reverb unit.
   / Restarting My '70 Nova Project #554
On a previous truck I actually installed new calipers on the wrong side and they wouldn’t bleed. You may find the caliper with the bleeder on the bottom very difficult to get the air out.
Never mind, it looked like you took it loose, flipped it over and bled it, which was what I was going to say.
Yesterday, I addressed some more little niggling items on the car. One was that the passenger door dome light switch didn't work. I took it loose, and I could tell the wire wasn't attached to it. Without taking the kick panel out there is very little space to get int that cavity, but with a piece of SS safety wire with a hook on the end I was able to fish it out the gap between the dash and door pillar. I was able to run another wire in through the switch hole, fish it out through the gap, tape it to the switch wire, pull it back out and get the switch attached and screwed in. It works now!
Another thing that needed attention was to do a rough setting of the toe-in one the front end. Just the little I drove it, in and out of the shop and up and down the driveway, I could tell it was way off. I saw an episode of Road Kill Garage where they use some jackstands, string and a ruler to get it set well enough to drive to the alignment shop. That worked fine, but entailed jacking it up and back down a couple of times before I got it close enough for my satisfaction. Should drive better now, especially since it has manual steering, like a real muscle should have.
One last thing I did yesterday was to hook up the hoses for the windshield washers. only took a few minutes, but another item crossed off the list.
The trunk carpet came today, so I unpacked it and laid it in the sun for a while to take some of the wrinkles out. It fit pretty well in the trunk, so I decided to go ahead and put the jack and spare tire back in, at last. I cleaned 11 years of dust an dirt off the spare and the jack, then got them put back where they belong. One more item checked off the list.
I also decided to reset the adjustments on the Cal-Tracks, as I hadn't adjusted them since it was off the jackstands and on the ground, so I had to jack it up high enough to get the jam nuts loosened up, let it back down, adjust the links, jack it back up to tighten everything back up, then let it back down again. I need an air operated floor jack!
I also took the vinyl top out of the box and laid it out in the sun on the drive for a few hours to take some of the creases out in preparation for being installed this weekend. It's been in the box for at least 10 years, but is still really supple and is laying down pretty well. I'm going to put it in the sun every day until the weekend, so it should flatten out some more by then.
I also installed a couple decals to replace ones that were removed or destroyed during the rebuild process. I need to do some research on just how many decals it came with from the factory, where they are installed and then see just how many are being reproduced. The folks on Steve's Nova Site have a lot of collective wisdom on matters like that.
Still waiting on the vinyl top installer, tentatively going to do it this weekend. Of course, it's supposed to rain Friday and Saturday and I have to haul the car on an open trailer, so we'll see what happens.
I talked to the window installer who is taking over for the gentleman that passed away a few months back. Her is working with the man's son to figure out who has glass in his shop and work with them to get it installed. They have not been able to find the rear glass for my car, however. The only thing we can figure out, is that he used it on another customer's car, and was going to order another for my car, but didn't have time to do it. So, the son is going to order another glass for my car, since I paid his father for it.
I did decide to install a fire extinguisher in the car, not only in case I might need it, but in case someone else has a fire. It's cheap insurance and I was able to put right between the front seats.
I also added a harness that connects the battery to a battery maintainer so I can keep it topped off while it sets idle.
I think I'm going to pull the seats out and lubricate the tracks, as I blasted and painted them before I installed them, but never did lubricate the slider tracks and rollers. That won't take long and will make them easier to slide if someone needs to get into the rear seat.
   / Restarting My '70 Nova Project #557
A friend had some new smoothie wheels blasted and powdercoated, and they came back coated over the sand in the crevice.
Seems to be a problem to get a good powder coat job on wheels. I wouldn't think new wheels would give a problem, as long as they get all the grit out of the crevices.
As long as it isn't raining tomorrow, the Nova goes to get the vinyl top installed. Outlook is pretty iffy....
Well, when the vinyl top installer said he could do it the weekend after the 4th, he meant the weekend after the 4th of July weekend. I'll try again next weekend. Or give up and install it myself.
   / Restarting My '70 Nova Project #560
Any updates ? I was hoping that you would get to enjoy it a whole bunch this summer. We,re almost into August.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Commercial truck Frame with Axle (A59230)
Commercial truck...
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
KUBOTA ZG23F ZERO TURN LAWN MOWER (A60430)
KUBOTA ZG23F ZERO...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
