RESOLVED 🛑 STOP sign on instrument panel
   / RESOLVED 🛑 STOP sign on instrument panel #1
GJohnson
Kemp, Texas
Bobcat ct225, ford 2000, IH 1086, IH 966, too many
This is a 2106 5055E cab tractor with 12x12 PR transmission with 800+ hours bought at auction that needed a rebuild. I drove this tractor and even loaded it after purchase. I have no previous history for it. When I got it home, it barely had enough compression to crank, but had no lights on the dash at all. I ran it for a few hours, blowby and gurgling oil from the valve cover. Obviously the rings were allowing compression to pass. It didn’t get hot or have any stored codes. The rebuild is done. Upon cranking it after rebuild, it started right up. However, I now have lights and codes. Codes include 102.04 = manifold air pressure sensor low voltage. 105.03 = engine inlet air pressure temp sensor voltage too high. 1569.31 = engine protection. This last one says (internet says) it’s in conjunction with other codes. Lights are STOP, DPF regen says it needs a parked regen as the button is flashing, engine information indicator is on as well. Engine is now derated to 1800 rpm. Again, no lights or codes before the rebuild. Am I now flowing too much exhaust pressure than what the computer was accustomed to reading? Because it’s derated, do I have to involve JD? I know there are some smart guys on here. All of your help is appreciated!
   / RESOLVED 🛑 STOP sign on instrument panel #2
Did you clean/replace/bypass the DPF?
No. As I said, it wasn’t asking for anything before the rebuild. I didn’t want to change the parameters unnecessarily as I realize how sensitive sensors can be.
   / RESOLVED 🛑 STOP sign on instrument panel #4
Being that it was running so bad before the rebuild, the DPF might be plugged. :unsure: Also, did you swap out the fuel for known good fuel. If not, you don't know if there is gasoline or even paint thinner in there.
It ran great, but had no power. The fuel in it has been replaced with fresh diesel from my tank with a filter. Fresh coolant and new oil. Fluids shouldn’t be my issue as they’ve all been changed. All of the filters have also been changed, even the cab filters. I only ran it long enough to ensure the coolant system was fully flowing through the heater core as it is above head in cab.
   / RESOLVED 🛑 STOP sign on instrument panel #6
Your not gonna have any power if the DPF is plugged like this. Does the exhaust sound and feel very muffled?
It had no power before the rebuild. It has plenty of power and compression now. Except it is derated. Never having a tractor with DPF, I can’t say what exhaust flow is or should be. It sounds right, but that means nothing really as I only have this tractor to judge that from. But again…it did not want a regen or have a stop prior to rebuild. Looking at the pic, my dpf filter looks nothing like that. It is white inside and I can see the ceramic quite well.
   / RESOLVED 🛑 STOP sign on instrument panel #8
You might have to have a tech hook up to it with the shop computer and check the codes and parameters. Keep us posted. (y)
   / RESOLVED 🛑 STOP sign on instrument panel #9
This one looked clean until this happened....wow.
   / RESOLVED 🛑 STOP sign on instrument panel #10
The OP is looking for different answers, and duplicated this thread question. To avoid confusion,
RoGator RG1100C (A52128)
RoGator RG1100C...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
71059 (A49346)
71059 (A49346)
2015 GMC Acadia SLT1 SUV (A50324)
2015 GMC Acadia...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
