resistance spec for LB1914 glow plugs?
   / resistance spec for LB1914 glow plugs? #1
dbotos
southwest VA
Ferguson TO-30, Kioti LB1914
Didn't see it in the service or owner's manual. Service manual had a line drawing of how to check it, but didn't give a value. P/N is E5205-65512 (replaced E5205-65511).
   / resistance spec for LB1914 glow plugs? #2
I've been told so long as you measure any resistance in the plugs, they are good. If you get a "O" ohm reading, they are open and not functional. Also, remove/disconnect the bridge between the plugs, so as to check each plug individually
   / resistance spec for LB1914 glow plugs? #3
A good glow plug is less than one ohm when cold. That's lower than you can accurately read on an ordinary ohm meter. But the resistance goes up substantially as the plug heats up to about 800 degrees. A healthy glow plug will stabilize at about 8-10 amps a few seconds after it's connected to 12 volts. About all an ohm meter can tell you, for sure, is if it'a an open circuit or high resistance (almost open circuit). So there is no useful ohmage spec.
Thanks. Perhaps that's why they don't give a value. I do have a clamp-style DC ammeter, so I could check the current as you described.
   / resistance spec for LB1914 glow plugs? #5
That is the ideal way to test the plug. Older/cheaper clamp-on meters only measured AC but new hall-effect probes do DC too. I wish I had one. They are particularly useful for cars. tractors, boats, etc. with high-current DC systems.
Figured I'd check the cold resistance just for grins while I had the wiring off the glow plugs. All three measured 1.0 ohm from the threads on the glow plug to a threaded hole in the head just forward of the front glow plug. Used a Klein MM100 multimeter on the 200-ohm setting (0.1 ohm resolution - lowest of the resistance ranges on it). Manual says accuracy of the resistance measurements is +/- (0.8% + 4 digit)...
+/- (1.0 x 0.008 + 0.4) ohms
+/- (0.008 +0.4) ohms
+/- 0.408 ohms
R = 1.0 +/- 0.408 ohms
R = 0.592 --> 1.408 ohms
So as ritcheyvs said, not the most accurate measurement (~41% accuracy).
Planning to measure current this afternoon. The Extech 38389 has a +/- (2.5% + 0.6 A) accuracy when measuring 0-70 A DC, so for 10 A, that would be +/- 0.85 A or 8.5 %.
   / resistance spec for LB1914 glow plugs? #7
I can't comment on your specific meter, but normally those percentage specs (e.g. 0.8%) are percentage of full scale, not percent of the reading.
When you first slap 12v on a cold plug, the current will spike to about 20 amp and then decrease exponentially (over a few seconds) to a steady-state value, probably around 8 amp.
Didn't have an FS or full scale callout, so I was assuming percent was relative to reading. 0.8% of 200 ohms is 1.6 ohms, which would be pretty horrendous on a 1.0 ohm measurement, especially when you tack on the 0.4 for a total of +/- 2 ohm.
   / resistance spec for LB1914 glow plugs? #9
You have that just backwards. They should be near 0 Ohm's. Slightly less than 1 ohm . open circuit is infinity. Not 0. Anything less than 1 ohm is difficult to measure on most meters. A piece of copper wire is near 0 Ohm's as well. Some call that a dead short. A piece of wire across a battery will draw a lot of current. Make a lot of heat and light, and maybe some smoke. Don't ask how I know these things.:D
Here are the currents I measured yesterday afternoon:
front: 15 A initial, 8 A settled
middle: 14.6 A initial, 7.6 A settled
rear: 14.9 A initial, 7.8 A settled
FYI - the little hex nuts that hold the wiring on are M4 x 0.7 (in case you happen to drop one and then can't find it). I did come up with a technique to help avoid that:
Essentially something to hold the nut until it catches the threads when installing or to catch the nut when it comes off the end of the stud when removing.
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
Liebherr PR736 LGP Crawler Dozer, S/N & PIN# 1155-17697, ID# 93501138, Turbo Diesel Engine, 13' (A59076)
Liebherr PR736 LGP...
2016 Chevrolet Tahoe (A55973)
2016 Chevrolet...
Rolling Drain Pan, 44" x 27" w/Pump to Drain (A59076)
Rolling Drain Pan...
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
