Residential Router with Remote Hard Disk Drive
   / Residential Router with Remote Hard Disk Drive
   / Residential Router with Remote Hard Disk Drive #12
Just installed a new linksys ea6900 wireless router which includes a usb 3.0 external port for storage (hard drives) or other usb devices such as printers; also looking for a network based shared storage solution. USB 3.0 touts much higher transfer rates https://en.m.wikipedia.org/wiki/USB_3.0. The router offers dual bands which translate into 2 separate networks at 2.4ghz and 5.0ghz allowing traffic from all the different wireless devices to be split to different networks, with the 5.0 ghz band optimized for video streaming, smart phones, smart tv's, roku, apple tv, cameras, etc. Have done that (about 20 wifi devices in the house) and it has drastically helped performance for all uses. I'm eager to see the actual throughput when using a USB drive to transfer files. The admin interface is much improved from years past and it offers a web app for network management which is a great tool also. There are alot of good routers out there, I have just happened to use this brand over the years, and been generally satisfied.
   / Residential Router with Remote Hard Disk Drive #13
Are you still using the seagate, just without their software?
<CSIHelper: 0x145e0d50>
Yes, I like the Windows backup better than the Seagate supplied software, it's a bit more straight forward and easier to recover data from it. I think they knew this and that's why there was not a win10 version created. When I inquired about it Seagate indicated it was a third party application they had bundled with the disk.
   / Residential Router with Remote Hard Disk Drive #14
Connecting (over wireless) to USB3 vs USB2 I would be very suprised if youwont see enough speed difference to notice.
USB2 is good for up to 480mbps and a good 5ghz router can theoretically hit 450mbps (less in real life depending on your location).
Most of the time, the bottleneck is the router (going from USB to WiFi or Ethernet).
Aaron Z
   / Residential Router with Remote Hard Disk Drive #15
Be very careful in connecting storage devices to the USB ports on routers. A coworker did this and there was a known security vulnerability that was NOT fixed by the router company. The ID of the person was stolen from data that was on the storage device....
It is a temptation to connect a drive this way but I just direct connect storage drives to my systems when I need them. Then the drives are put away in a drawer away from power surges and hackers.
Later,
Dan
   / Residential Router with Remote Hard Disk Drive #16
Later,
Dan
Is that hacked router vulnerability any different from directly accessing the original drive that the data came from?
   / Residential Router with Remote Hard Disk Drive #17
One suggestion is to use a 2 disk Synology Diskstation such as DS215j along with 2 NAS hard drives such as Seagate 2TB NAS HD. I am currently backing up my laptops and computers to my diskstation which is configured as a mirror raid set, you are also able to use the diskstation as a media center, photo gallery and many other apps that can be installed in the disk station manager. It is a more expensive option but it is a very flexible option also.
   / Residential Router with Remote Hard Disk Drive #18
Curious why you'd want to use a router to backup your laptop, when the speed would be way higher if directly wired to the router. You could still have the hard drives attached to the router, but the download would be much quicker if hard wired, then unplug after completed.:confused3:
I've got a Bazillion bits/sec fiber from my ISP, but the difference in speed between wireless and hard wired is ridiculous! Wired the download speed bends the needle on the meter, wireless, still fast but nowhere near as fast.....
Convenience. Tell the machine to backup at 3:00am every night. No need to connect anything and it won't matter if it takes a lot longer. Also, safety, as in, each time you pick up a USB hard drive and connect it to a laptop, you risk damaging the ports on the laptop and dropping the USB drive.
   / Residential Router with Remote Hard Disk Drive #19
   / Residential Router with Remote Hard Disk Drive #20
I think you're missing what I'm trying to convey. I'm saying that having a 2T or 3T drive attached directly to a router port, then use the router, via hardwire to a laptop to download/backup, etc. INSTEAD of trying to do the backup, or whatever by the router's wireless connection. Doing backups at 3 AM makes perfect sense, whether wired or wireless. BUT quality and security of the data transfer would be highest via wired connection, IMHO.
2000 GMC C6500 SINGLE AXLE BUCKET TRUCK (A57880)
2000 GMC C6500...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2023 Load Trailer (A55787)
2023 Load Trailer...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
