Resetting service indicator - Sharing how to.
   / Resetting service indicator - Sharing how to. #1
OLV1071571
Bronze Member
Central Arkansas
Kioti RX7320P
Just wanted to share with the forum the process for resetting the service indicator. This is the process for the 3500 series so it might be different for you depending on your model.
1. Open fuse panel located under steering column left side.
2. Pull the 10a fuse from the top right of the fuse panel. Mine was labeled turn signal but the dealer said it shouldn't matter what its labeled.
3. Insert 10a fuse into the empty "reset" spot.
4. Turn the ignition to the on position but do not start the engine.
5. Wait 30 seconds and turn the switch off. (For me the service indicator did turn off)
6. Then replace the 10a fuse into its original spot
7. Start the tractor and the service indicator light (the wrench) should be off.
Hope this is helpful for the community.
   / Resetting service indicator - Sharing how to. #2
Or use a OBDII scan tool to reset it.
There you go trying to make things easy again! LOL :laughing:
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2025 KJ K1230 UNUSED (10) Wire Mesh Netting Rolls (A50860)
2025 KJ K1230...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
1240 (A50490)
1240 (A50490)
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
