Researching: 48" 3-Pt. Cultivator for BX2230 >> Blueberry Patch
   / Researching: 48" 3-Pt. Cultivator for BX2230 >> Blueberry Patch #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Seeking 48" Cultivator which will fit Cat 1 Three Point Hitch on Kubota BX2230 sub-compact tractor. NEW or USED. North Florida
Will be used to cultivate 48" rows between Rabbiteye Blueberry Bushes in 3/4 acre Blueberry patch.
Using a TSC 48" Chain Harrow now. Need implement with more bite.
There does not seem to be much available for subcompact tractors.
(Owner of BX2230 is physically incapable of connecting PTO, so roto-tiller is out.)
Suggestions?
Thank you.
   / Researching: 48" 3-Pt. Cultivator for BX2230 >> Blueberry Patch #2
How about something like this.
Compact Tractor 4 Shank Toolbar Cultivator And Bedder Combination - McGee Farm Equipment, Inc.
Or, he has the same thing without the middle buster and bedders if those are not needed.
Of course, you can buy different size sweeps to reduce any gap between sweeps.
If you look on his site under "3 Point Toolbar Equipment" and "Tractor Tillage Equipment", he has quite a selection.
Most of them are pretty light, which might work for the owner with physical limitations.
Good reference.
CLD124 48" Toolbar Culivator appears complementary to BX2230.
$356.25 for 85 pound tool is doable; additional $211.50 shipping for 85 pound tool is a killer. ($567.75)
Have you had any experience with implements from this unnamed toolbar implement manufacturer?
   / Researching: 48" 3-Pt. Cultivator for BX2230 >> Blueberry Patch #4
Good reference.
I bought the six shank model, but haven't tried it out yet. (Still on pallet...) From looking at it, I think it is well made and worth the money. BTW-If you call you order in, you can request a 10% discount on freight charges. I would suggest speaking with them and trying to work out something more palatable as far as shipping. My experience was top notch with them.
Is there a manufacture's name on the box? I would like to seek one locally.
   / Researching: 48" 3-Pt. Cultivator for BX2230 >> Blueberry Patch #6
Sorry, no name on it.
Cultivator information you referenced specifies: NOT FOR SUMCOMPACT TRACTORS.
Thank you for the effort.
   / Researching: 48" 3-Pt. Cultivator for BX2230 >> Blueberry Patch #9
Sorry, my bad. It makes me wonder though, your BX2230 has a Cat I hitch and the cultivator has a Cat I hookup. Maybe the height of the lift pins would keep the tractor from picking it up with enough clearance???
Curt Receiver Hitch (A51573)
Curt Receiver...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2024 KMC 7406 (A53084)
