required air flow for small sandblaster
/ required air flow for small sandblaster #21
Donman said:
I live ten miles from the Lake Michigan shoreline and know from my former life as a residential builder that none of the cottages on the shoreline used aluminum siding back when it was popular because the high volumn low pressure air (wind) would sandblast the paint off in a matter of days. My leaf blower is rated over 100 mph. Gotta think that would work - just don't know how fast and good.
If you were content with spending days on each spot it would work perfectly.
Larry
/ required air flow for small sandblaster #22
i have a 13 cfm 60 gal. comp. and the f/h 50 pound pressure pot sand blaster it works great the sand i use is home depots silica sand just make sure ya use the respirator i hear the stuff isnt good for the lungs..jon
Just bought a 450 liter per minute 4 hp 400 volt compressor today.
It's an old one, but for painting a small hobby compressor has to run 3 hours continuously which causes it to overheat and ceise, like my current 215 liter 1,5 hp compressor did during a paint session.
This old beast is a slow rev 3 cylinder industrial, driven by a 4 hp power washer motor. It was a home assembly of a fairly new, high quality pump and a used pressure washer motor. It can put out 450 liter per minute and max 12 bar.
The shop tool trader will replace a cracked pulley and install new air filters for me, and i can pick it up next week for 200 Euro. I think that's a fair price for an old but reliable industrial unit.
Does this rig change my bet in the sand blaster matter, or would it still be insufficient for sand blasting ?
/ required air flow for small sandblaster #24
I missed this thread in January, but I will mention the same thing I always do when the subject comes up. If you don't have a huge compressor, but you do have an average sized pressure washer, a sand blasting attachment for your pressure washer could solve your problem inexpensively and without straining your equipment.
For around a hundred bucks (what is that, about 60 Euros these days?) you can get an attachment for your pressure washer that will siphon sand at the spray tip and shoot it with the water. It is very effective. In addition to eliminating the need for a monster compressor, this method eliminates the problem of dusty breathing hazards. It is a little messy, but that's all. I have used mine on several pieces of equipment, and it does a great job. The pressure washing cleans off the crud and the sand blows away the rust and old paint.
I don't know if it's available in your country, but you should check out POR-15 paint. I just used it for the first time, and I don't think I will ever repair a piece of equipment without it again. Using an HVLP spray system I used about a pint (little less than a half liter) of POR-15 to put 3 coats on a 60" MMM deck. The instructions say you can spray it on over rust, so I was not concerned about the slight bit of surface rust that comes with pressure washer sand blasting. It took almost a quart (liter) of JD yellow to spray 2 coats on the same surface area.
JMR TREE BOOM (A61572)
1997 International 3800 School Bus (A64194)
1997 International...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
213063 (A64276)
213063 (A64276)
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A65643)
2014 RETESA 210BBL...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
