requesting digital camera update
/ requesting digital camera update #31
Glueguy
Thanks for the heads up on pixels. The greater number of pixels then wouldn't allow the camera to be used in a lower light situation, but might pull out more detail in shadowy area?
SHF
/ requesting digital camera update #32
You can get cameras with shutter speed control, my Sony DSC-D770 has quite a few shutter settings that help when it is extremly bright or if it is quite dark. The more options a camera has the better as it allows you to take shots in all different situations, however it does get more complicated but you will get the hang of it.
/ requesting digital camera update #33
<font color=blue>The greater number of pixels then wouldn't allow the camera to be used in a lower light situation, but might pull out more detail in shadowy area?</font color=blue>
That is mostly correct. If there is sufficient light for the CCD, then more pixels will pull out more detail in all situations. If the CCD's aren't sensitive enough, then no number of pixels will help (sorta like 1,000 x 0 is still zero).
/ requesting digital camera update #34
To echo GlueGuys remarks...
Do not be seduced by a cameras pixel count. I supposed manufacturers use pixel count because it's easy to quantify just as tractor manufacturers use horsepower ratings. There's so much more that goes into getting a good picture. For first time digital camera buyers my advice is, absent a specific intended use, e.g., sports, wildlife, which can imply the need for specific features.
1. Buy an inexpensive digital camera. It almost doesn't matter what brand or kind or what features it has. All the major brands will be able to take a good picture.
2. Use the camera. /w3tcompact/icons/smile.gif This is kind of obvious, but some people only take pictures at birthdays and holidays which really isn't enough opportunity to get to know what you like and dont like. Take indoor pictures, outdoor pictures, action pictures, stills.
3. In addition to not being seduced by pixel count, also determine which features can be duplicated in software, e.g., sepia tone.
4. Once you've used a camera for a while you will be in a much better position, assuming you've kept track of your likes and dislikes, for purchasing your second digital camera (yes, there will be a second camera for most of us!).
Some other observations;
Distant wildlife - High optical zoom
High optical zoom - Image stabilization or the use of a monopod/tripod
Stop action - fast shutter speed and buffering of pictures
Low light - High ASA speed (800 and above), image stabilization, monopod/tripod
Lots of flash photo - Good battery life and recovery of battery/flash
Toro Sand Pro (A56859)
2020 DRAGON ESP...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
