Replacment alternator
   / Replacment alternator #1
kinghesh
Yanmar ym2000bd
Hey y'all,
I have a Yanmar ym2000bd and I need to replace the alternator and I am wondering what brand I should use. I have look into it a bit but just wanted to see what people with more experience say.
   / Replacment alternator #2
Hey y'all,
The simplest solution is go to Autozone etc and tell them you have a 73 Datsun (Nissan) 510 without air conditioning. Same alternator and regulator.
Or you could tell them 'With A/C' for more amps, but that alternator is fatter. So you would need to make a longer adjustment strap, longer belt, maybe a different mount under the alternator.
As I recall the Datsun-spec alternator is 25 amps vs 10 as supplied to Yanmar, or something like that. In the same outer shell.
I did this in 2003 (regulator too) and it still works fine.
   / Replacment alternator #3
Rebuild the one you have. I finally had to get mine rebuilt for a YM2000 same starter in 6/2011 for 75.00$. Not the first complaint. US. JD. 240 also same starter. Not much to them. The shop mentioned they could see were I was in the brushes of mine. It quit and I added an extra 3yrs use out of the starter just basicly cleaning it up and turning them around!!! Any Auto Eec. shop should do it.
   / Replacment alternator #4
Just before you spend the money on a new alternator, be certain that the entire alternator circuit is working. That was the problem on my JD, which I found after I spent the money for a new regulator. For my experience, the wiring harness seems to be about the most trouble prone parts of tractors/ATV's, all the things which plug in seem to be more reliable!
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
Club Car Carrryall 502 (A50121)
Club Car Carrryall...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2018 Dodge Grand Caravan SXT Van (A50324)
2018 Dodge Grand...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
