Replacing water pump on LX178?
   / Replacing water pump on LX178? #1
PIMCO
Norway
JD LX178
Hello, good folks.
Got a hand-me-down 1991 JD LX178 with the water-cooled Kawasaki FD440V engine.
Upon finding oil with milkshake texture and searching the web, I have come to learn that the water pump is of a somewhat flawed design allowing water to access the crankcase when pump gaskets fail (?). I hope head gasket is not culprit, compression seems decent and engine runs okay (apart from whiteish smoke).
Found water pump with two associated gaskets (part # AM134588) on eBay for $80. Question is, is that all that is needed? I seem to recall having read that there are some seals or O-rings associated with the pump assembly?
Thanks in advance for any pointers.
   / Replacing water pump on LX178? #2
Could pressure test instead of guessing ? The PCV system can go wrong on those and draw crankcase oil into the intake.
That Kawasaki engine is considered robust if not abused .
The K61 transmission is much more robust than the scrawny flimsy K46 used in the 100 series and low end 300 series units sold today.
Thanks for the feedback.
I don't have pressure testing equipment, is there a shortcut to ruling out head gasket? It seemed to deliver okay power and the oil/coolant seemed to mix really quick.
I would venture to guess that a failed PCV valve would be more of a seeping phenomena? I had milshake oil after just a couple minutes running after replacing the oil.
I am not able to find a PCV system in the electronic JDPC parts catalogue?
   / Replacing water pump on LX178? #4
I posted in your thread in John Deere Owning Operating. See that post
Thanks, I will follow up with you over there.
LOT LOCATIONS (A51219)
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
2019 POLARIS RANGER 4x4 UTV (A51222)
2019 POLARIS...
1267 (A50490)
1267 (A50490)
UNUSED Grey Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Grey...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
