replacing turn signal on L2900
   / replacing turn signal on L2900 #1
Fastball
North Okanagan, British Columbia
Kubota L2900
Hi all....
Just finished smashing my round rear amber flashing/turn light assembly on a low hanging branch. Bought a new 4 inch amber light assembly, figuring it would be a matter of cutting and splicing a couple of wires. But no.
The original has only one wire leading to the bulb holder and the new light have two wires. I'm assuming the other wire for the original is tied up in the wiring harness someplace. Can I buy an assembly with a bulb base with only ONE wiring coming to it?
   / replacing turn signal on L2900 #2
Is it mounted on a metal fender and the light assembly grounded thru the metal frame ?? If so just connect the ground wire of the new lamp to the under side of the fender with a small lug and machine screw/nut. Remove some paint under the lug of course.
gg
48in Forks Loader Attachment (A49346)
48in Forks Loader...
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
2016 Ford Focus SE Sedan (A48082)
2016 Ford Focus SE...
2008 Ford Expedition 4x4 SUV (A48082)
2008 Ford...
2019 Allmand Trailer Mounted Light Plant (A50860)
2019 Allmand...
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
