replacing turn signal on L2900
   / replacing turn signal on L2900 #1
Fastball
North Okanagan, British Columbia
Kubota L2900
Hi all....
Just finished smashing my round rear amber flashing/turn light assembly on a low hanging branch. Bought a new 4 inch amber light assembly, figuring it would be a matter of cutting and splicing a couple of wires. But no.
The original has only one wire leading to the bulb holder and the new light have two wires. I'm assuming the other wire for the original is tied up in the wiring harness someplace. Can I buy an assembly with a bulb base with only ONE wiring coming to it?
   / replacing turn signal on L2900 #2
Is it mounted on a metal fender and the light assembly grounded thru the metal frame ?? If so just connect the ground wire of the new lamp to the under side of the fender with a small lug and machine screw/nut. Remove some paint under the lug of course.
gg
ATV Racks (A50860)
ATV Racks (A50860)
2015 Ford F-550 Auto Crane 4004EH 4,000LB Service Truck (A48081)
2015 Ford F-550...
2024 Case IH Magnum 340AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2009 IC Corporation PB105 School Bus (A48081)
2009 IC...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
