Replacing Tire/Rims on Farm Trailers
   / Replacing Tire/Rims on Farm Trailers #1
downslope
Platinum Member
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I have some home-built single axle trailers that are used off road around the farm pulled by tractors at low 5mph speeds. They are built on old medium duty front truck axles from the 40's and 50's. Tires are like 7.00x20 and 7.50x20 on split ring rims.
As the tires are failing I would like to cut out the center sections from the old rims and weld them into some salvage yard rims. What size rims and tires should I look for where used/bald salvage tires would be plentiful and hopefully cheap and/or free now and in the future?
   / Replacing Tire/Rims on Farm Trailers #2
Wouldn't it be easier to replace the axles/wheels from junked trucks 50 years newer??? MikeD74T
   / Replacing Tire/Rims on Farm Trailers #4
them slip rims are just dicey. i'd go with a conventional rim.
many places you can get blanks, or as said.. use something more common you can find in a junkyard..e tc
   / Replacing Tire/Rims on Farm Trailers #5
In your situation, I would probably do just what you are planning. Around this neck of the woods, 11R22.5 is the most common size - used on dump trucks, highway tractors and trailers, etc. However, this is a much wider and taller tire than a 7.50 x 20 and may not have clearance space on your trailers.
   / Replacing Tire/Rims on Farm Trailers #6
I too agree to keep it as simple as possible.
If they are different size wheels throw one of each size into the truck and head out for a truck junk yard.
How about mobile home axles and springs with load range g tires. You can get them pretty cheap.
It wouldn't be so simple. Remember these are custom made, no suspension, axles welded to frame, tie rods /king pins welded in fixed position, etc.
If I could just find some modern rims with the same bolt patterns it would be easy, but I don't know if that will happen. One of the axles is like from a 1940's Dodge 1.5 ton truck, with 5 giant lug nuts on a Budd type wheel. The other one is even worse, some kind of spoked wheel. I'll try to post some pictures tomorrow. Maybe I can alter some 19.5" rims. Thanks for everyone's advice.
   / Replacing Tire/Rims on Farm Trailers #9
Why not pick up a set of junk yard steel wheels with modern 15" or 16" wheels. Something of a 80's GM truck come to mind. Have a local machine shop cut out steel blanks using 3/8" material with the proper lug pattern. You can then torch or better yet plasma out the centers of the wheels and weld in the new blanks.
For the speeds you are going even if its off a 1/4" its not going to make a difference. 16" truck wheels would be the ticked to me. Plenty of used LT 16" tires floating around that you could get cheap.
Chris
   / Replacing Tire/Rims on Farm Trailers #10
5 mph? Just get some junkyard 16" rims, take off what you have, push a foam plate into the lugs to make a jig, trace it on the 16", drill and mount. Use washers in back for spacers if needed.
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2014 INTERNATIONAL LF687 SLEEPER (A52576)
2014 INTERNATIONAL...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
