Replacing the water pump bearings on Yanmar YM2000
   / Replacing the water pump bearings on Yanmar YM2000 #1
piotrbpm
Hi I am new to the forum and not really know English, I come from Polish and need help in dismantling YM2000 Yanmar water pumps.
Some time ago bearings in the pump started beeping and I want to mention them, just do not know how?
Maybe someone undressed and will share how to dismantle?
Do I need to use the puller and the gunboats from the fan?
Thanks for any help:)
   / Replacing the water pump bearings on Yanmar YM2000 #2
i would just buy an already rebuilt one, sorry i cant help you much.
   / Replacing the water pump bearings on Yanmar YM2000 #3
This sounds like a job for MJPeterson:). He can probably walk you through it in Polish.:cool:
   / Replacing the water pump bearings on Yanmar YM2000 #4
That was what I was thinking as well. I haven't seen him post in the last few days. He must be away on a trip or something. Hopefully he will be back soon and can advise.
   / Replacing the water pump bearings on Yanmar YM2000 #5
MJ Peterson is an American member of this Yanmar forum who lives in Warsaw. He can explain in Polish, or translate for you.
Here is his page on TractorByNet. 'Contact info' on that page has a choice to send him a PM (Private Message), and also shows his personal Home Page in Warsaw.
Here in the US most of us would buy a replacement, re-built pump for about $90. Or maybe take it to a local rebuilder so he can put bearings in it.
I have read that some times the impeller inside (fan, propeller, the part that turns) has to be replaced because of corrosion, so a replacement may be needed.
   / Replacing the water pump bearings on Yanmar YM2000 #6
Hi guys nice to know that I am missed. :laughing: I actually am in the States for a couple of days for a conference. Thanks for the confidence, but I am afraid that I do not know how the pumps come apart, or even if it would be possible to rebuild them. In Poland labor is cheaper than buying parts so if a bushing can be made it will for sure be less than buying a part--if you can find the part.
Piotr, Dzien dobry!! Witamy do TBN! Nigdy nie naprawiłem pompę wodą ale myślę że nie jest dużo inacznej niż jak do samochodu. Może podobny do toyota albo Nissan od 1970 - 1980. Gdzie pan mieszka? Mieszkam w Otwocku--nie daleko od Warszawy. Jeśli mogłbym pomogać,chcę. Wrócę do Polski 8-ego marca. Może do mnie pisać po polsku w PM.
Cześć,
Mike
   / Replacing the water pump bearings on Yanmar YM2000 #7
Ok my Polish is a little vague (actually this is all I recognized! :D) but that looks like excellent advice. Any shop that could rebuild a 70's Toyota or Datsun (Nissan) water pump would probably have the right bearings on the shelf, and the needed skill. Yanmar was good about using 'world' parts on their 70's tractors.
I think there are a couple of different YM2000/YM240 pumps. Maybe the fan mounting is the only difference, I don't know.
Hello again, thanks for the many interesting topic:)
I've already written a message to MJPetersen and now look forward to answer:)
The most curious to me that we need to chase the hot ...
If I can manage this problem will present the forum is how to go about doing this:) pozdrawiam of Polish
A mieszkam w woj.lubelskim nie daleko miasta Nałęczów:)
   / Replacing the water pump bearings on Yanmar YM2000 #9
"chase the hot" :confused:
Can you say that again, in different words?
   / Replacing the water pump bearings on Yanmar YM2000 #10
"Chase the hot" = Maybe he's not married ? :D
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
John Deere 6100D (A50120)
John Deere 6100D...
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
Bale Ring (A50515)
Bale Ring (A50515)
STORAGE FEES (A52577)
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
