Replacing the oil seal n a kubota L3710 hydraulic pump
   / Replacing the oil seal n a kubota L3710 hydraulic pump #1
Jmichaelhyman
Monticello, Ga
Kubota L3719
I have the pump off and a new seal but do not see how to remove the old oil seal around the shaft that goes into the engine. I have removed the clip ring but the seal seems seated do not want to scratch the walls. How do I remove?
   / Replacing the oil seal n a kubota L3710 hydraulic pump #2
Is the seal rubber covered? The oil seal will most likely have a rubber lining with a single or double lip and should be spring loaded. The old shaft seal should just pop right out You shouldnt have to worry much about scratching the walls
   / Replacing the oil seal n a kubota L3710 hydraulic pump #3
If you don't have a seal puller ( I have used 2 different kinds, one from snapon and the ones that OMC have) try a screw driver and pry out. Go slow and work around the shaft it should come out ok.
Hyster H225E (A47384)
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
(APPROX 20) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 20) 2" X...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
