Replacing the generator for a 12 volt alternator. 53 farmal super C
   / Replacing the generator for a 12 volt alternator. 53 farmal super C #1
feleds
Lisbon, Ohio
1953 Farmall super c
I need instruction on how to do this. I thot their was a thread but I couldnt find it. Can I use the generator pulley? Where do I hook the 1 wire coming off the alternator? I assume I dont need the regulator. Its already changed over to 12 volt. What ever else I need to know would be helpful. Thankyou. Sill new at this but learned a lot fixing and repairing this old tractor
   / Replacing the generator for a 12 volt alternator. 53 farmal super C #2
Pulley size matters, because you want the alternator to operate in the correct RPM range.
I'm not sure which wire you're talking about without knowing the make/model of alternator.
You most definitely will need to use a regulator (assuming the alternator doesn't have one already built in). Alternators produce voltages much higher than 12V. The regulator is needed to keep it at 12V output to the rest of the system.
Its an ADR 0335 10 side 105 amp one wire
It’s a delco
Ok that was clear enough in hooking up the wires. Now how about do I need a new bracket for the alternator or can I use the existing generator bracket? What about the pulley. Can I use the one off the generator?
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
Gravely Proturn 472 (A50123)
Gravely Proturn...
