replacing teeth on scarifiers
/ replacing teeth on scarifiers #1
MLB
Fort Wayne,IN (NE)
New Holland TC33D
Do you heat them up before pounding them? I've just done it cold, but i''ve lost several this year.
/ replacing teeth on scarifiers #2
Yes I would heat them so u can get a good crimp on them.
If I was lossing them I'd weld them on and just refresh them w/ a piece of leaf spring when they get wore down.
I've never lost any teeth on the scarifier but do lose then on the hoe buckets.
But I was also told to consider them as a shear pin. if you hit a big enough buried rock you knock the tooth off instead of transmitting the force through the 'shank' and maybe breaking that. FWIW
/ replacing teeth on scarifiers #4
If the box is level or tipped down in the front , a rock is going to push the tooth on more so I don't see the tooth coming loose unless u rip the back out of it.
I have hit lots of rocks and everything else, it just spins the wheels.
Even on my 7000+# SSL which has lots more power than my 35D the only weak point is bending the lower 3PT pins.
So is a propane torch hot enough? Or do I need a welder type heat?
/ replacing teeth on scarifiers #6
Gas axe type heat, it needs to be atleast red and orange would be better.
/ replacing teeth on scarifiers #7
My torch is propane/oxy, and worked great for the one Boxblade scarifier tooth and one Backhoe tooth that came off and needed to be reattached. Can't remember if I heated to red/orange, as Hoeman suggests. but once it was heated, the metal "crimped" very easily with hammer and blunt punch. I was impressed with how easy the job was with the help of "heat".
I assume a non-oxified propane torch won't be quite as hot, but if that's what you have, it would sure be easy to try it and see if it works.
OkieG
/ replacing teeth on scarifiers #8
<font color="blue"> just refresh them w/ a piece of leaf spring when they get wore down.
</font>
I replaced a missing Boxblade tooth with a brand new one. The new tooth was too long. I expected all kinds of trouble cutting it to match the other teeth, thinking it would be very hard metal. To my surprise, it cut very easily...like it was mild steel. I like your leaf spring idea, as I also thought about welding longer new teeth on top of the short old ones.
OkieG
soft is right! the two teeth I lost I kept on blading as the bare shank still cut in just fine. Wore the tips down way more than I would have thought possible that quickly. Had to replace one shank because it ground it down too much for the tooth to seat on. That's in 2 days use!
/ replacing teeth on scarifiers #10
U can't believe how fast DIRT can wear steel.
We've got a 5 shank subsoiler from Case that runs a wing type tip.
The wing lifts the whole soil profile and fractures the hardpan.
We run around 18-22" deep.
The wings are really hi $$$ and don't last over50-60 acres.
The dealer said they weld backhoe teeth onto the front of the wings to get them over 100 acres a set now.
We are replacing springs in our spray truck all the time and I keep the pieces, they work great for building up the tips on teeth.
MLB do u still have the shank?
Just weld the tip on and keep it for a spare.
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
1995 Kenworth W900 Studio Sleeper (A62613)
1995 Kenworth W900...
Club Car Golf Cart (A66285)
Club Car Golf Cart...
John Deere Gator (A62613)
John Deere Gator...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
FECON CEM36EXC2-FS-XXV-0LPK11 DRUM MULCHER (A64277)
FECON...
