edkemper
- Joined
- Dec 1, 2013
- Messages
- 305
- Location
- Klamath Falls, Oregon
- Tractor
- JD 210LE, Case 580CK Series B Backhoe, 1991 WoodMizer LT40 Log Mill, 1989 JD450E Crawler Tractor, FordsonMajorDiesel
I have a JD210LE. I want to replace the teeth (ends) on the scarifier shanks. The shanks have a dimple (shallow hole) on each side and the teeth have a hole in them that lines up with the dimple. I am supposed to dimple (punch) the hole in the teeth into the dimple on the shanks to hold them on the shank. If that makes any sense.
Do I pound a punch to cave in the hole on the teeth or should I just remove the shanks and take them and the teeth to a shop to have them use a press to install the teeth?
I can buy a 12 ton free standing shop press or an 8 ton bench press from harbor freight for $130/$75 respectively and I could do the repair myself.
Any guidance would be appreciated.
