Replacing Teeth on Grader Box
/ Replacing Teeth on Grader Box #1
GuyL
South East Louisiana
2006 Kubota 4330
I need to replace two teeth on a Woods grader box. The originals must have been pressed on as I see no old bead on the scarifier. I should also say that the Woods replacement teeth seem to fit loosely. Anyone replaced these teeth before? I was thinking of either welding them on or filling the teeth with JB Weld and beating them on. Any advice appreciated.
/ Replacing Teeth on Grader Box #2
Agri-Supply has a couple of styles of teeth and the complete rippers too. See page 40 of the current Buyers Guide.
Agri-Supply page 40
/ Replacing Teeth on Grader Box #3
I've had to replace 3 so far on my 7' Woods box. Just use the replacements (Woods or generics) I heat mine with a torch 'till cherry red (just over where the indentation is located) , then peen the indentation with a punch. The replacements seem to hold up just as well as the originals. They will break from time to time. Welding them makes it far more difficult to change again later. I'm not sure there would be any advantage to having them fixed so tight they can't move.
/ Replacing Teeth on Grader Box #4
I cut mine off with the plasma. It was suggested here to drill out the dimple, then tap them off, but it was just much more fun (and quicker) to slice them with the plasma and take them off.
I marked where the dimple in the shank was on the tooth then put a 1/4" nut where I wanted the dimple, then pressed it down into the dimple with my press (20 ton)
Hope that made sense.
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
Hydrapack 6 Row Lay-By-Rig (A64127)
Hydrapack 6 Row...
Kubota L3901HST
Kubota L3901HST
(1) 30 Yard Roll Off Dumpster and (1) 20 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
2021 TORO TRAILER (A65643)
2021 TORO TRAILER...
New - Front mount rototiller
New - Front mount...
