Replacing Some Hoses
   / Replacing Some Hoses #1
Scare Crow
Taos, New Mexico
John Deere 950
I have several hoses to replace on my FEL something I've never done before. What should I expect? any pressure at all in the lines with the tractor off? Will the lines need bleeding when I'm done or will cycling the FEL a few times do the trick? Any pointers on this I can get would be greatly appreciated.
-Mike-
   / Replacing Some Hoses #2
What you said is correct.
Mark the ports and hoses with paint or tape.
   / Replacing Some Hoses #3
I will recommend before loosening any hoses to cycle the FEL control levers a few times with engine off to relieve any trapped oil pressure.
   / Replacing Some Hoses #4
I have several hoses to replace on my FEL something I've never done before. What should I expect? any pressure at all in the lines with the tractor off? ...
Probably depends on whether you have the FEL raised or lowered ... ;)
(Make sure it is lowered before you disconnect any lines ...)
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2013 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2013 MAXEY TRAILER...
Swamp Buggy (A49346)
