Replacing Some Hoses
/ Replacing Some Hoses #1
Scare Crow
Member
Taos, New Mexico
John Deere 950
I have several hoses to replace on my FEL something I've never done before. What should I expect? any pressure at all in the lines with the tractor off? Will the lines need bleeding when I'm done or will cycling the FEL a few times do the trick? Any pointers on this I can get would be greatly appreciated.
-Mike-
/ Replacing Some Hoses #2
What you said is correct.
Mark the ports and hoses with paint or tape.
/ Replacing Some Hoses #3
I will recommend before loosening any hoses to cycle the FEL control levers a few times with engine off to relieve any trapped oil pressure.
/ Replacing Some Hoses #4
I have several hoses to replace on my FEL something I've never done before. What should I expect? any pressure at all in the lines with the tractor off? ...
Probably depends on whether you have the FEL raised or lowered ... ;)
(Make sure it is lowered before you disconnect any lines ...)
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
(3) New 23X8.5-14 SS tires on 6-lug John Deere compact tractor rims, Coal Valley, IL (A65640)
(3) New 23X8.5-14...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Mitas Tire (A65640)
Mitas Tire (A65640)
2005 Ford F250 XLT Super Duty (A66408)
2005 Ford F250 XLT...
Altec DC1317 Chipper (A63689)
Altec DC1317...
