Tiller Replacing seal on king kutter tiller
   / Replacing seal on king kutter tiller #1
taylor6400
Ohio
JD 4600
I have had a kk tiller for about 3 years now. I bought it a year old and in nice shape. Haven't had any problems. Keep it greased and oil checked. The last 2 years the shaft has beset around the hub but never noticed low fluid but now I go to use it and it was almost empty. So it looks like it's the dreaded seal. For now I drained it and filled it up with 00 grease hoping to be able to till a few acres for fall food plots in the next couple weeks. Will just keep a real close eye on it. But over winter i want to replace the seal. I know it's been done here and I have read some posts but I want abetter idea of what I'm getting into with only hand tools.
Couple things I am wondering. What kind of weight am I talking when I pull the gear box off and it looks like the back shield will come off at the same time. How heavy is that sucker and how do I support it? Then is the hub pressed onto the shaft? I understand the only gear I have to remove is the lower one. I'm no mechanic...can I tackle this? Any pointers? Looks like the biggest hassle is getting to the bolts that bolt the hub on.
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
CATERPILLAR SKID STEER QUICK ATTACH PALLET FORKS (A51243)
CATERPILLAR SKID...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
28013 (A50322)
28013 (A50322)
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
